All Activity
This stream auto-updates
  1. Past hour
  2. They might pull good money on Ebay. I've never checked sold prices, but people ask a fair bit for them.
  3. Today
  4. This is the type of bread I like to dip into hummus. I normally heat the bread for about 15 seconds in the microwave as I store them in the refrigerator for longer shelf life.
  5. Bump...last call...otherwise they'll just hang in the shed collecting dust for the estate sale...🙃
  6. I wouldn't say it's ABnormal here... hoping for some rain in May.
  7. Good idea. And fucking hail, in late April. What the actual fuck. I wonder if people are still saying that this is normal weather for the last year.
  8. There's currently an ongoing hailstorm outside here, but once it's over, let me go down to the shed and get the one I have out. I'll measure it and snap a couple pics. Maybe give it a try first? It's a pretty good one, don't remember the brand though.
  9. No, totally generic. They come in a wide single model and a narrow dual. Pretty sure for a motorcycle I want the wide single. With the low truck height, I might be able to deal with it without a second ramp. But if not, an ultra cheap small ramp will be the answer. https://www.amazon.com/gp/product/B00GM859O6/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&th=1
  10. So I think will order that ramp/extender, and go from there. Doesn't seem like I would be wrong with that, and if I want the carrier later, not a big loss and likely still useful.
  11. I would use only the finest Chinesium tubing stated as being super strong. 2" square tubing should be enough, but they sell couplers for 3" so I might go the overkill route just to feel good about it.
  12. Yesterday
  13. I can think of two easy DIY bolt-on extensions that won't require modding the trailer. A straight square tube from the front of the frame extending under the coupler as far as needed, or a T attached to the V section of the tongue and extending forward past the coupler. The front part of either could be attached to the existing coupler by installing a ball on it, the rear could be U-bolted or through bolted with nuts.
  14. I've been told that WD hitches are pointless on this truck because of the air suspension and weight of the truck. At least in the scale of the small TT. The bed extender wouldn't necessarily be to use with the TT, but could be useful in general. The fact that the same dollars gets me a ramp and the extender is the main benefit. Neither bike can fit in the bed with the gate up, and whether the Zero might fit with it partially up is open. The XR, no way, and it would be the one to go on trips with the trailer. Check out my measurements; best case, the XR tire would barely be on the tailgate. Removing it is out of the question. So gate down is going to be the only option, and how the TT works would be a matter of either a tongue extension or truck extension. I had the Wellcraft trailer extended, don't remember the cost, but not enough for me to remember because it hurt my ass so much. I decided to draw it out to be sure. Bed Length at Rail - Tailgate Up 1373 mm or 54.1 in. Bed Length at Floor - Tailgate Down: 2130 mm or 83.9 in. Bed width (exposed cargo width): 1299 mm or 51.1 in. Bed wheelhouse width at the floor: 1277 mm or 50.3 in. Bed Height with Tonneau Open: 465 mm or 18.3 in. Max Cargo Height (Tonneau Closed): 434 mm or 17.1 in. Bed Volume: 828 L or 29.2 cubic feet Something is sketchy between the diagonal and straight measurements which I have listed as the same. I believe it's because of the differences in floor versus rail/cover space; the cover and rails eat space. I need to measure again, and it's off for paint correction right now. Fuck, I need new whiteboard markers. Now to measure and draw the bike footprints.
  15. A bed extender would solve the bike hauling, but not allow the trailer unless you did an extended hitch which is gonna suck for weight distribution. One option would be to extend the trailer's tongue, that would allow tailgate down while reducing tongue weight, and allow for using the distribution hitch if wanted. I bet it wouldn't take much to create a "bolt on" solution rather than doing a permanent tongue mod.
  16. A great point, and a feature that this doesn't have. Wonder why? The Gladiator had that, specifically called out because it has a short bed. It let me carry multiple sheets of full-size ply. Afro-engineering in 3...2.... I really think that I should get the combo ramp and bed extender. Then see how that feels for loading and carrying, and go from there. Every post I can find about trailering is about the same; bigger impact on economy than carrying cargo. And the fucking 55 limit in CA, and just the annoyance/risk factor of it. I'm not going to own one, and while U-haul isn't super far, it's another thing to do before trips. https://www.amazon.com/Extreme-Max-NR002N-Xtender-Combo/dp/B007K9D7NG/ref=sr_1_3?dib=eyJ2IjoiMSJ9.fC_Kl9lB4qJyk6LqNIoYA4DT86pmY1E8QMosKbRIVeAe0CznBpoTAsU9deib62al9qE97Fv9LXZuV0kAtxFLiPcUrZJH3O_Z3dUVf2-SuCBuATjjd2IzefzYiv5LO1nIsT3iDoyGkey-OY5R2vXX8kCducUnOdTyjla6VOp0BscErnttqywibyzPCQCho526W7U65bJi5D8ZesHa_GmQwQkczTYYClwEZVuHdJwd6mzkMP6ELHfXRWZF-PaROqU9OyAZ0S-anOxgBmWFdddpCAGe6eoEOiRExofm08hTIYQ.Ees3UXgA_cTOT2-euTflN2Bat6DLrmrZ9pt8kMgn5_Q&dib_tag=se&keywords=ready+ramp&qid=1713964323&sr=8-3 https://www.amazon.com/Extreme-Max-NR002S-SLVR-Motorcycle-RampXtender/dp/B00GM859O6/ref=sr_1_2?dib=eyJ2IjoiMSJ9.fC_Kl9lB4qJyk6LqNIoYA4DT86pmY1E8QMosKbRIVeAe0CznBpoTAsU9deib62al9qE97Fv9LXZuV0kAtxFLiPcUrZJH3O_Z3dUVf2-SuCBuATjjd2IzefzYiv5LO1nIsT3iDoyGkey-OY5R2vXX8kCducUnOdTyjla6VOp0BscErnttqywibyzPCQCho526W7U65bJi5D8ZesHa_GmQwQkczTYYClwEZVuHdJwd6mzkMP6ELHfXRWZF-PaROqU9OyAZ0S-anOxgBmWFdddpCAGe6eoEOiRExofm08hTIYQ.Ees3UXgA_cTOT2-euTflN2Bat6DLrmrZ9pt8kMgn5_Q&dib_tag=se&keywords=ready%2Bramp&qid=1713964323&sr=8-2&th=1
  17. The dude, not Swamp, is probably the only person in United States, that includes cops, who gives fuck about speed limit while towing small trailer. And he is wrong. Montana, for example, has 75 mph speed limit for heavy trucks. That would be 18 wheeler. Pretty much same in Idaho. Can't imagine it would be lower for pick up towing small trailer. I'm guessing real reason is retarded layout of charging stations. Very few are gas station type pull thru. It either back aor pull in in case of EVs. That means dropping trailer every time you need charge. Very enjoying.
  18. If the tailgate can be removed and the bike will fit diagonally, that would let you tow the trailer. Or maybe with the tailgate partially open.
  19. Try other brands, you will find some that are thin and break, some that are thick but also crunchy, and you may have hit the middle ground where they don't really crack but also don't fall apart like the thick ones.
  20. The wife is getting into the hummus thing and we ended up getting these plus pita chips and bread. The bread is really good but I don't eat bread, (can't control myself), the pita chips are harder than we like. I can eat all of them but the honey jalapeno is my favorite.
  21. Last week
  22. I bought the last one at a Kroegers- Fred Meyer store and I prefer it over Sabra. You may not like it like Carlos.
  23. It's at most of the "weird" stores like Sprouts and Whole Foods. It's the only brand I will never buy again. Chris and I may have opposite tastes, LOL.
  1. Load more activity
